Hi, I am trying to create blow up details in ORD V10. I tried to do these details in the sheet model which worked fine until printing - it causes it to crash and create massive PDF's so I'm wondering if there is a good way to do this with named boundaries, and if not what is the best way to do this in just the default 2D model?
update - making the details in the sheet model (by referencing in my design file) rather than the default 2D has seemed to work well and not cause the file to crash.
How are you doing this? What is your process?I personally would do this by hand, just attaching whatever file or model you have collected your base references in as another reference attachment. Clip that attachment to your circle element, and that should be it.
I don't know enough about setting up all of the named boundaries and seeds and all to know how to leverage the automation.
MaryB
Detail view creation is covered in our Intor to Sheet Creation vidoe below:
https://www.youtube.com/watch?v=zIqlEexj6tQ&t=26s
Kelly Sextro said:it causes it to crash and create massive PDF's
Can you share the files fore view and testing?
