When bringing in survey data from a text file, how can I change the symbol related to it? Right now it is a blue circle with a X.
From my understanding, the survey has a Code for each point and the Code relates to what symbol is given to each point. Where would this info be hiding where I can edit the relation of code to point symbol?
For example, our surveyors take a ground shot and label it "GND". And when I import my data each point with GND Code would have a X symbol.
Cory, a blue circle with an 'x' means that ORD Survey can't find the field code ... so it's placing that default symbol. Do you have a Workspace with Feature Definitions created that equate to the field codes you are using?
Sorry I edited my original post before seeing this. Yes, I am using ALDOT workspace where they have set up everything. If I go into the dgnlib folder and edit the feature definitions how can I edit or add codes and symbols?
Here's a pic from my ORD Survey book that shows an example of the bread crumb trail from the Feature Definition to the Element Template to the MicroStation resources.
Here's a video that I did a while back that covers how to create a new Field Code. This should tell you what you want to know.
https://www.youtube.com/watch?v=xM9o8SbgNu0&t=163s
Answer Verified By: Cory McKibben
Amazing video!! This clears up much of my confusion!
