Good Morning,
I am trying to export a survey book to ASCII file format, Is there a way to export the data to this format in ORD?
Emily, one way to do (and you're soooo close) is to right-click in the far upper left corner of the Survey Details and Export. If you pushed it to a CSV you can clean it up and have a nice comma delimited ASCII file.
Another way is to right-click below that in the first blank column and Export to a LandXML and then do further reporting from there.
If it was a snake it would've bit me. Thanks!
