Looking for some advice on how to Query a Station using the ORD "Civil Analysis by Point" tool. That tool outputs Stationing readings in three (3) different places (marked in my screen capture below by red arrows) but none of these data points seem to be selectable to Copy/Paste into a another field, into excel, notepad or whatever else.
Is there a keyin that will query a geometry that outputs a selectable field for copying?
Matt Bombace said:Query a Station ... Is there a keyin that will query a geometry?
If you're not asking a question about C++, C# or VBA then this is the wrong Forum. Move your post to the ORD Forum. Use the More=>Move button.
Hi Matt,
as Jon wrote, because your question is about OpenRoads Designer and not about MicroStation Programming, please move this discussion to the right forum. Please do not ask again to avoid duplicated post, but use Move tool as Jon described.
Also, please follow the best practices and always specify the used product and its exact version.
Matt Bombace said:Is there a keyin that will query a geometry that outputs a selectable field for copying?
I think no such key-in exists (but I am not advanced ORD user). Maybe you should create a new idea how the tool should be enhanced.
With regards,
Jan
Hi and thank you for the responses.
I had already asked this question within the ORD forum with no luck on a viable solution. I was hoping to learn about possibly using a Key-In (if one exists) to query an object and possible write a VBA to do something within ORD, using the MIcrostation platform, which is why I posted within the Microstation Programing forum. I know a bit of C++, C# and was hoping to use that knowledge in compilation with the advice I gained from the forum, and from you fine people to get me pointed in the right direction. Thank you.
All programming questions should be posted in the programming forum. Development is responsible to reply to those.
Here is a link to the Civil Programming forum.
(+) Civil Programming - Bentley Communities
Try the ORD SDK - there is an example called PointAnalysisReporter that should do what you are looking for.
Mark
