Is there a way to change the template that is being used in a corridor, along with the drop interval?
Power Geopak SS10, 08.11.09.918
Was able to accomplish both by using the Element Information tool > Templates > Template Drop > change the interval and template used here. May be an easier way but this is what I found.
PowerGeopak SS10 v08.11.09.918
Yes, this works. You can also access via the quick access toolbar when the template drop element is selected or in the corridor objects dialog (bucket).
Justin Guiliano, PE
Justin, thank you for that information.
