Is there any way to export templates from a template library to a DGN file?
I'm thinking about the old CellTool, which could be used to print out the contents of a cell library for documentation. I know that wouldn't work here, but I can think of a few reasons we might like to create DGN files/models from our templates.
Documentation is one, for certain. While I can only imagine the work involved, I can see the benefit of documenting our templates and components. While I know that the templates themselves can include documentation links, it would be quite helpful for that documentation to include an illustrationThe other use I immediately thought of was the generation of typical sections. Since our template would, indeed, be our most "typical section", it would save a certain amount of energy to be able to get that in DGN format and pop it onto a sheet.
So, is there any way to generate DGNs of our templates?
Thank you.
Mary, would Display Template do what you want?
Matt
Answer Verified By: MaryB
Well, it's something, but it's coming in all on the Default level, not using any of the features/levels used in the actual template. It also doesn't show any of the null points, so it's of limited use for template documentation.It is better than nothing, though. I can work with it.Thank you!
MaryB
It really sucks that this tool works so badly compared to how it used to work!
Exactly!!! Look at this comparison. ... it's not a comparison. Apples and an apple core.
Indeed!As I said, better than nothing, but far from what I was hoping for.
