Creating a proposed profile and I need help with getting the profile station & existing elevation from plan. I’ve tried to use Civil AccuDraw and get the correct station but not the existing elevation. I have the existing surface set as my Active Terrain Model. As a note I started from https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/229850/how-to-quickly-navigate-one-point-station-from-plan-to-profile. Not sure what I’m missing.
Power Geopak SS10, 08.11.09.918
I ended up using the Profile Offset to get the elevation. Probably a better way but a workaround none the less.
PowerGeopak SS10 v08.11.09.918
Hi Robert,
please keep in mind that questions in English should be posted in the dedicated forum:
OpenRoads/OpenSite Forum (English).
This will help not only us, but also you to get a proper answer. I am moving your post to the English language forum, so that someone could help you. :)
___
Best regards,
Klaudia
