Using OpenRoads CE 2022 R1 seems like the Profile "Create 3D Cut" is not working. When adding the Create 3D cut nothing shows even though there are 3D elements in the model. When adding additional elements to the 3D model and attempting a "Refresh 3D cut" nothing happens. When opening files created in prior versions of geometry with a 3D cut defined the 3D elements display but do not update and do the turn off when deleting the 3D cut from the profile view.
Is this happening for anyone else or just me? I can test on a different computer with a fresh install.
Working now. Must have been something I did.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Is this the parametric 3D cut or some other tool. If you can share an example I can review for any issues.
It is the ORD Profile 3d cut tool - Video: Create 3D Cut in Profile - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities.
Mark
