Automated Catchment Delineation and Inlet Dimension Settings
Does anyone know where do change the settings related to where the catchments see the grate location and dimensions? This is in OpenRoads Designer 2022 R1.
In the example below I have a combination intake. The magenta catchment is linked to the intake shown. You can see the "V" is more or less centered on the origin of the intake rather than the grate. The white catchment is from the downstream intake and seems to roughly match the grate width dimensions but doesn't match the upstream catchment. Both catchments are also too far upstream on the grate by a few inches but that is a relatively minor issue. The major issue with this is the gaps and overlaps between the two catchments. Overall, it looks like the amount of overlap and missing areas should come out as a nearly a wash. The problem is it raises questions about accuracy and does not look good for plans and exhibits.
I have messed with the catchment delineation settings and just got more of the same. Changing the catalog inlet dimensions as well as any dimensions in the Hydraulic Properties doesn't seem to do anything. I also didn't see anything in the node or catchment feature definitions.
Catchments
