Hi.
I have a template running along a track with a point control dependant on the cant.
This works fine in ORD 2021 and before but in ORD 2022 it no longer computes.
The point control is there, the template just doesn't respond to it.
This is a picture with the point control active in ORD 2021:
And here, the same same spot, same alignment, same template and same point control in ORD 2022:
It fails to activate the point control and raise the duct with an extra layer of fill under neath.
Has something changed with how superelevation is handled between 2021 and 2022? Or is it a bug?
Edit: Changed the picture to more clearly show it is the same spot
did you upgraded the file containing the Cant "superelevation", the track alignement and the Cant element need to be also upgraded. I had problems with Openroads where I needed to redo the superelevation (for roads) so you may need to redo the Cant in Openrail for this to all works.
Answer Verified By: Simon Edlund Stephensen
Ill be damned. All I did was to open the file containing the geometry in Rail2022 and then saved it. Now it works.
Is this working as intended? Why does the geometry file need to be done in 2022?
Every major version of software of OpenX product have a specific "civil-schema". When a major new release come out you need to updgrade all the files to this new version to make everythings works. You can do this by either opening all the files or use the civil manager tools to do it all at once.
Thanks for your help Jeremie!
