Unable to access Help Contents.
Hi Michael,
Are you trying to open online help in OpenRoads Designer? File > Help > Help Contents?
This should take you to this page: https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT%20Edition-v14/en/GUID-1B18BC16-7361-4DA1-BC57-D8A9EEF3F9E7.html.
Does opening it in another browser work?
___
Please keep in mind that questions in English should be posted in the dedicated forum:
OpenRoads/OpenSite Forum (English).
This will help not only us, but also you to get a proper answer. I am moving your post to the English language forum. :)
Best regards,
Klaudia
Thanks for the link. I had found the help files earlier I just wanted to know why after updating to 10.10.21.04 that the link from ORD quit working.
from the screenshot it looks like its pointing to the qa site. the page may be cached.
How are you accessing the help the F1 key or the help button?
