After creating a terrain from a point cloud, is there a tool to create points on that terrain in a grid pattern of desired spacings? If so what tool would you use.
The Elevation Difference Grid tool can be used with a Mode of "Terrain to Plane" and a Plane set at "0" to annotate the elevations of points at user defined grid spacings.
https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT%20Edition-v14/en/GUID-84EB8712-0CC1-4C5A-BD3E-ECB1CC1059B9.html
It looks like this will work, but I'm not seeing the "Elevation Difference Grid" tool in the drop down for points under the Terrain/Analysis ribbon. I'm currently running OpenRoads Designer Release 1. I'm wondering if this may be part of Release 2.
Thanks for the help.
