Fairly new to ORD, coming from MicroStation V8i.
I have generated cross sections using the named boundary tool. There are certain levels on from a survey file that show up in my cross sections (existing fence, existing bridge, home concrete foundation). I cannot turn off those levels; they appear on my cross sections as a section-cut graphic. In the level manager, hovering over any level says "Level State is controlled by Saved View. Level is ON in Active View."
Where do I go to turn off these levels? How do I access "Active View"?
I would first try your 3d model levels and any references within that. If that fails you may have luck changing the saved view itself
Ironically, right after my post, I found that you can change "Synchronize View" to "Settings from Design Model". This allows users to simply turn off levels from references/models. See the following link for more: communities.bentley.com/.../how-to-turn-on-off-levels-in-drawing-sheet-model-when-getting-message-level-state-is-controlled-by-saved-view
