I am looking for some specific help with a cross section grid annotation issue that my coworker and I are experiencing. We have both recently transitioned from V8i to ORD CE 2021 R2 and have been scouring the forum (and google) for specific information on cross sections and annotation. We have explored this helpful link: Cross Section Point Annotation Troubleshooting and watched all the youtube videos on ORD cross sections (I have some feature requests at the bottom - if anyone reads this post an knows how to execute the desired outcome in ORD CE please let me know)
- TLDR of the issues: The cross section grid is annotating itself above the minimum elevation of the data contained within the 3d- model and the units (and width / height) of the grid annotation is ~3x larger than it should be (along with the named boundary size being 3x large than specified)
(1) The "Cross Section Grid Annotation" issue:
- My coworker and I are on two separate projects but both are in imperial units. We're working from an ORD projectwise environment whose job is also in imperial units (TxDot based if matters). Our previous project was metric, so both of our guesses is that we're self inflicting the "id10t" error since no one else on the internet seems to have this issue.
- I experience this issue when cutting sections from a txdot seed file without using any corridors; my co-working has tried the generic bentley seed file using corridors and also experiences this issue.
- I don't know if there is anything else i can add other than the civil labelling tool is also recognizing the elevation of the terrain differently from the 3d model as if it was in metres
(2) - We have checked the design file settings (linear units showing feet, slightly confused at why the advanced settings have meters)
- The best part of making this post is that i changed the advanced settings to read feet and doing that resolved the horizontal grid spacing not matching the dimensions (but the vertical spacing is still wrong)
However the elevations are still being scaled incorrectly. You'll notice that the civil labeller is showing an elevation of "6599.56'" below the bottom grid axis which is showing 6530 feet.
(3) The next issue is that the named boundary was set to +/- "30" in the setting and the named boundary that was output is measuring 98.452 on either site; meaning it converted from metres to feet.
* But wait! The grid annotation has taken that 98.452 named boundary offset and put the grid at a -300 offset (which is confusing because 98.452 m = 323 feet)
- Lastly, the correct elevation for this section should be in the 2150 to 2175 range which is being recognized correctly in the 2d and 3d views
We have also checked the models units and set them to feet
Any help on the units would be appreciated issue would be appreciated, I suspect there is something silly that we're both missing - we're just exhausted trying to find it.
Lastly, regarding some features of ORD CE;
- Is there a replacement tool for automatically labelling the depth? In V8i I had ~ 100 km of pipe depths to label from invert to a surface. I created a section label that would provide a nicely formatted depth label between two known features. Is there a way to utilize the civil labeller in this fashion? For example, reading the elevation of a profile and measuring the distance to another feature? In my case I had two alignments, one at the top of pipe and one draped over the surface. I just read the 2022 release notes, and it sounds like maybe this is a new feature
- Given that named boundaries have completely changed the section tools, is there a new way to incorporate sections that have deflections? I know they can be rotated for skewed sections and such, but is there a way? could this be logged as a feature request? This was one of the most powerful parts of sections from V8i in my opinion (being able to cut a single section over a large drainage network to understand interactions with other parts of the model)
Are all your seed files and DGNLIB files using the same units of resolution? They need to, the DGNLIB that contain the Cross Section Sheet definitions needs to match the file you are cutting cross sections in. Just in general all your ORD files need to have the same Units of Resolution within the workspace for annotations and sheeting to scale appropriately. This is also true for cell libraries used with ORD annotations, all cells used should have the same unit of resolution or the scale will be off by the difference factor(s).
With MicroStation alone this is not an issue typically the "True Scale" functionality within MicroStation mathematically resolves background resolution differences when placing cell or attaching references. ORD does not do that.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Answer Verified By: KYLE TITUS
Thanks for the quick explanation, Yep, changing the "resolution" to match the dgn lib file has fixed issue (1) where the grid was offset from the actual section so thank you very much for helping with that!
OpenRoads Designer Connect Edition - Annotation and Resolution Units
I am still experiencing the incorrect vertical grid labels (scaled by 3.048) and the width of the named boundary is still scaling incorrectly. Aside from the design file settings of the problem file, are there other variables I should be looking at?
Edit:
The issue is resolved now, it was primarily a problem with the units of resolution as Mike suggested. Steps to resolve, recreate the file from a blank seed. When referencing the original dgns the unit issue needed to be addressed. Initially re-creating the sections still had the units wrong (scaled by 10 instead of 3.048) but after a dgn crash i was able to recreate the sections and have everything annotate correctly
This doesn't address your main issue, which is very obviously Unit related (I believe Mike is on the right track)...You can cut a profile along any feature you like - it's not restricted to just "alignments". If you had a flow/control line feature or such that ran through your drainage network, you would be able to use that to generate a profile/"long" section.
MaryB
Thank you for your reply, I believe that would be a suitable replacement as there is now the ability to show other 3d objects in the model onto the profile sheets
