Is there an Item Type Expression to add an Item Type with a Civil Elements "Feature Name"? There is a Function Group in the expression builder "Civil Element Properties", but it does not appear to have any sub functions.
Hi Mike,
It should be this.GetElement().FeatureName.
Remember to set the "Last Valid Value" to true so this property is retained when used in Microstation or iTwin (when the property is not able to be calculated outside the Civil environment)
Video: Item Type Syntax for Nodes and Conduits - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
Mark
Sound good, even seems to be documented in the wiki you linked but does not seem to work. The expression builder does not recognize the .FeatureName and returns my "Failure Value" in the Item Type when used.
OpenRoads Designer CE - 2022 Release 1 - Version 10.11.00.115
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Thats weird, works perfectly for me. This is a basic one that we use quite a lot so not too sure why its not working on your end...
Answer Verified By: Mike Longstreet
OK, got it to work. It does not register in the Expression Builder but will work if the syntax is correct.
