Triangle display behind elements
When I turn on triangles they are "on top" of the linework.  I'd rather have them behind and still see all the linework.  Is this possible?
  • The Triangles are a 3D element in a 3D file, your "Linework" is the corridor lines I assume.  So, the Triangles are a reference in a 2D file.  The update sequence for references can change what line vs graphics appear on top even if the elements are below the triangles.  This found in the Reference dialog > Properties > Update Sequence. In the update sequence list the first files in the list will appear under the last.  So, in the image below s22a183og_dtm.dgn (a 3D file) appears below the graphics in the last file in the list s22a183us2corridor.dgn. You can move them up and down in the list as needed.  Your corridor file should be a 2D file with a managed 3D model.
    Mike Longstreet
    Vermont Agency of Transportation
    Civil Engineering Technical Support
    VTCAD Help
  • Sorry about that.  I'm talking triangles in my survey file.  I'd like the survey figures and any linework above the triangles.
Reply Children
