Terrain Smoothing turns off
I have a file where the terrain smoothing will not work.  It just kicks back to none.  This is a 3D survey file that has has corrections done in it, so a redownload of the survey data is not an option.  Any thoughts on this?  What will I lose if I merge this file into a new blank 3D file?
  • Do you have a Feature Definition applied to the Terrain? That always points to a Terrain Element Template. And in the Element Template, it should have that setting. If you override it in the properties of the terrain, it can reset to the value in the Element Template. You need to modify the settings in the Element Template being used if you want it to be persistent.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
Reply
    CADD Manager
