Happy new year all,
I am working on an Illinois Department of Transportation (IDOT) project in OpenRoads Designer CE 2021 using their custom workspace. I have created a corridor using templates modified from IDOT's stock library, and have the corridor's end conditions referencing an active terrain model. This is the second time I have used OpenRoads, as opposed to PowerGEOPAK, to create corridor models and cross sections, and the first time all files, including the workspace configuration, are entirely on ProjectWise. I cannot for the the life of me get anything to show in my dynamic cross section viewer, and I have tried all of the following:
In addition to this, I can cut cross section sheets and linework is created.
All I see in the dynamic cross section viewer is a blue diamond at the active profile elevation.
I am thoroughly stumped. I have followed the wiki article on this site with several solutions to this problem, and none of them have resulted in any change. Any help is appreciated.
Will Vierling
Is it empty or is the graphic in the view super small. I have seen this happen when there are extra graphics referenced into the 3D model and the window fits the extents around graphics that are far apart sometimes 2D graphic are in the 3D model and this can cause the vertical extent to be very tall.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
While I've previously had the problem you've described, this isn't the case this time. Check out my reply to my own post for a screenshot of what things look like.
Here is a screenshot of what is happening. Null points, key points, and even cut and fill graphics are displayed.
