I am trying to import some profiles into Open Roads Designer using the Import/Export tool to select a gpk. This typically works for me and is still working for coworkers on the same project. However, on my machine it throws this error:
It could be that you have some missing libraries built to handle certain functions related to GPK files. Do you have Geopak installed? If not, installing Geopak might resolve the issue as it will install all the relevant libraries that are not necessarily deployed when only installing ORD.
