test10.dgnHello, I am trying to delete an invalid element (attached image). I have also attached the file. It is at the NW corner of the intersection.
I have been looking around and learned previous people who have been facing the same issue and this is the best answer I could find (does not work)
Have you set the "junk" level as not active? ie. Just make sure that you have set active level to something else before running the keyin.
Thanks. I think this made it work!
