Hello
while doing corridor reference there is gap between reference element and corridor. while doing gore and ramp
Screen shot with mark up is attached for reference.
kindly suggest how to remove gap.
Can try add Key Station(s) in the corridor modeling.
communities.bentley.com/.../key-station
jing jing (o'.'o)
hello
i have also added key station but yet it is not woking. please find attached image with key station but yet gap did not remove
You case quite similar to this training course.
Maybe you can share the screen capture one more time or file(s).
You need to add a key station 0.001 in advance of your corridor reference at both approaches. Ie if your corridor reference is between station 100 and 120, your key stations should be at 99.999 and 120.001.
Answer Verified By: M Jain
its work. thanks
