Hello everyone. My problem is that when I click on the corresponding icon, the dialog box from Civil Labeler does not pop up. Absolutely nothing happens. My version of OpenRoads is 2021 release 1.
I often see it happen where the civil labeler opens but the area where the different label styles should be is empty. This appears to be some sort of refresh or maybe display driver issue. If you dock the labeler and then in dock will clear such a situation
Robert Garrett Senior Consultant
www.envisioncad.com
https://idot.illinois.gov/doing-business/procurements/engineering-architectural-professional-services/consultant-resources/highways/cadd/support.html
Shawn is correct the IDOT workspace is set up for 10.10
I have the same problem and i defined the labeler, thing is in training it does work but in my own setup it shows as this
i have these variables, but they are set up that they work both for training and my own workspace still it shows only on training
