Extract Vertical Profile from Linear Template
3618.test10.dgn
Attached is an intersection drawing I am working in (working in 2D view). I need to extract vertical profile information from particular lines of a linear template tied to an alignment that has an active profile associated with it. If I select the alignment itself, my application is able to identify that it has a vertical profile (below image):
However, if I select one of the lines generated from the linear template (construction lines turned off), my application fails to recognize a vertical profile associated with the line. For example, in the image below I am selecting the back of the sidewalk from the linear template.
I am using the linear template Curb/Gutter/Buffer - Sidewalk - Tie Slope (below image):
Any help would be appreciated.
Thank you!
