I want to show 20m offset ground and Level in Longitudinal section while exporting. In attached screen shot you can see line of 20 m offset line is generated but level is not displayed. With the default seed it show only design line and Level, OGL line and level of below ground but not 20m offset.
Kindly guide/provide video link to create new seed file to add 20m offset OGL level (LHS and RHS)
What software are you using and how are you creating the offset profile?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
It would be better , if you mention the software and its version you are trying ( MX, ORD, INROAD etc). I guess you are trying with ORD, to get the Ground Levels of the Offset Alignment in Data Band.
Babulal
Hi
To show OGL Levels for offset Alignment in the Profile Drawing of a Base Alignment.
1. Create offset Alignments (10m, -10m)
2. Assign surface profile to the offset alignments and assign active profile.
3 Use project profile to element (from offset alignments to Base Alignment) , in this method you will be able to create profile lines of offset alignments in Base line Profile drawing.
4. Copy a Annotation Group of Profile Drawing....and try to Edit it. You need to use concept of "ALIASES" to select offset Alignment Profile while creating profile drawing. And this will add Offset Alignment Ground Level to band.
Hope you can better understand from the attached files
8032.AnnotationDefinitions.xml
Agree with Mark Shamoun
What software are you using for your design?I see "ZWCAD" in your image. ZWCAD is not a Bentley product, and if that is where your issue is, you will need to contact them for help.If you are trying to run MX or another package on top of ZWCAD, I do not think that is a certified combination. What you are attempting may not work.
MaryB
I am using open road designer. Image is attached for your reference
