Hello
Are your levels off using View Display or Global Display? Your DWG export settings will define what level control is honoured in your export.
Mark
hi,
I am using Level display to level off (screen shot is attached). i don't know regarding global display.
please provide step/video to export plan in .dwg format in open roads
Use Global Level display instead, or use these instructions if you want to use View display: How to maintain the level display when saving to DWG. - MicroStation Wiki - MicroStation - Bentley Communities
The Microstation forum/Wiki has a lot of information about DWG export, eg. DGN to DWG export adds all turned off Levels - [Archived] FileFormats Forum - MicroStation - Bentley Communities
