We've imported survey data and referenced our 2D alignment file. We are now trying to run a station offset report. First, it asks to select the alignment we wish to have offsets from and we do. Next, it asks to select the elements we want the station/offset of. We aren't able to select any of the elements in the file as all of them say "element not valid for tool". We are unsure what's causing this.
Support for 3D elements in the Station Offset report was added in OpenRoads Designer 2022 R1 as noted here: https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT%20Edition-v14/en/GUID-6343270D-95BD-4548-9D31-0CE16AD1F810.html
