Utilities line styles, cut and fill limits and, BMPs line styles are coming in too large. For instance, I produce cut and fills normally by creating a corridor and template drops, set my annotation to 1" = 40' for instance and cut and fill limits come in too large by default. All the other text in the sheet looks OK because it was produced as well with that same 1"=40' annotation scale. Those particular line styles mentioned before are unproportionate to any other text in the plans. Tried changing the Global Line style scale = Reference; it will affect the default model (to whatever annotation scale I have my referenced dgns set to), but the line styles in the sheet model are unchanged (this is what I'm eventually printing). Yes I have toggled off "Scale Line Styles By Reference Scale". If I try to change the detail scale of the references, the reference completely moves location. Plans don't look presentable with text size coming in at one size and line styles coming in at a different size when my annotation scale is set correctly. I would prefer not to mess with the dgnlib as it is a DOT workspace. What should I do?
