I'm using the create cut fill volume tool which picks up the whole design model against the existing terrain except one triangular looking area:
I even tried swapping out some of the corridors:
Any ideas what type of situations cause this? It's a simple model and the existing terrain covers a much larger area than the design so overlap shouldn't be the issue. Also can't see any particularly interesting features in the existing terrain in this area. Tried it in the original topo this complex terrain was based on, no difference.
Ken
Hi Ken,
Are you using a Complex Terrain for your existing surface? [ORD 2022 R1] Create Cut Fill Volumes not following active terrain - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
I am actually although I think I tried it on one of the originals too, I'll double check.
Make sure all parts of the complex terrain have a feature definition assigned which has the volume option set to existing
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
