Hi
Is there a similiar tool in OpenRoads Designer as the Move to Surface in Civil3D? Where you can move 3d elements like 3d Solids/Blocks like houses to Surface elevation (terrain)
The Stencil tool in OpenRoads just work for closed polygons.
/Sigfús
Hi Sigfus,
You could do this by creating a Geometry Point that includes the cell you want to move to surface and it could be ruled to a Terrain, Mesh or Alignment. The issue is, as with the c3d tool, is that it will only move the cell's insertion point.
The great thing about the stencil tool is that will add additional points to the object to have it include all grade/slope variations in the surface you are draping it to.
Have you tried the Microstation Populate tool?
The Populate Tool: Part 1 - Populate Single - YouTube
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: Sigfus Jonsson
