ORD 2021 R2. When using the civil labeler. We have to close the civil labeler before going to a new file or model to be able to use it in the new file or model. Otherwise it locks up ORD and have to close down and open the file again. Anybody else coming across this issue? It's really annoying when going through multiple sheets and labeling R/W points or flowlines on pipes and culverts on cross sections. To have to close the labeler then open it up again.
Thank you,
Bob Morton
Yes, sir, can confirm. I brought this up with the product team and I believe there was an SR filed. If it’s not already fixed in 2022 R1, it should be so in the next release.
-John
OpenRoads Designer 2022 Release 3 | ProjectWise CONNECT 3.453
