As I'm trying to develop our Civil labels, it looks like I can only use one text favorite per label.Is there any way to string together multiple favorites into one label?
For example, I have a number of combinations that we use for station/offset callouts of R/W points.
Depending on the requirements, we can use 0, 1 or 2 decimal places. Some labels actually don't give the station and/or offset and just reference the R/W line. So I need Civil Labels like:
Sta (0D) / Off (0D)Sta (1D) / Off (1D)Sta (2D) / Off (2D)Sta (0D) / Off (0D) Lt/RtSta (1D) / Off (1D) Lt/RtSta (2D) / Off (2D) Lt/RtSta (0D) / RWSta (1D) / RWSta (2D) / RWSta (0D) / P.L.Sta (1D) / P.L.Sta (2D) / P.L.R/W / Off (0D)R/W / Off (1D)R/W / Off (2D)P.L. / Off (0D)P.L. / Off (1D)P.L. / Off (2D)R/W / Off (0D) Lt/RtR/W / Off (1D) Lt/RtR/W / Off (2D) Lt/RtP.L. / Off (0D) Lt/RtP.L. / Off (1D) Lt/RtP.L. / Off (2D) Lt/Rt
If I can parse together more than one text favorite into a label, I only need to create nine favorites. If the Civil label can only be a single favorite at a time, I have to create this whole list.I would much rather create the pieces, and build a label to meet the need, rather than try to craft every possible permutation we might need.
I'm sure I've asked this before, but can Civil Labels be created on the fly, at the time of need, without mucking up the resource XML? It's pretty common to need something that hasn't been preset. In Civil 3D we can create new labels pretty easily that are just saved into the drawing. We do our work, don't mess up the networked resource, and keep moving. Since ORD Civil labels are written to the centrally located XML, it looks as if any new labels need to be created in that file, which is NOT the way we want it. Or does everyone end up with their own personal Civil Labeler XML that they have to open to make new labels? What happens if someone else opens the drawing, and wants to place another one of those labels (but they don't have access to the personal XML)?
Thank you.
Bump?
MaryB
Civil Label targets are linked to the text favorite fields you create. You don't have to have 1 text favorite with 1 civil element field in it. You have a text favorite for station and offset (Plan Annotation.Point Station & Plan Annotation.Point Offset) you will have the ability to specify Target 1 and Target 2 independently if desired.
Same Label selecting 2 different references for target 2 (offset) - 1st is relative to the ROW line, 2nd is relative to the baseline. You can tailor the descriptions of the targets to instruct the users to pick the appropriate target for the text favorite. Looks like you've identified which text favorites you can consolidate.
Balancing modifications to a client provided XML vs. mapping to a workset specific XML per project is always difficult. I've seen people make project specific XMLs and utilize those going from project to project. I haven't tried opening an XML and copy/pasting the data from one to the other, but that may also be an option. I know others in here have messed around with that, so I would defer to them. I see this as one of the benefits of moving to the DGNLIB in the newer versions. It allows users to make these custom labels then copy those back to a workspace location.
HTH,
Justin
Justin Guiliano, PE
Answer Verified By: MaryB
MaryB,
There is no option to adjust the decimal places in the Civil Labeler so you would need different Text Favorites for all the different label formats. Also if you use station equation labels you may need separate Text Favorites to show equations labels. I learned this the hard way.
Note: Text Favorites are full pathed to the dgnlib in the xml file. So if you switch to a different text favorite dgnlib file or rename the original dgnlib file you may lose all your labels created in the Civil Labeler.
Zane Pratt
Civil Designer
Unfortunately, due to client version requirements, I will not be upgrading to a newer version (with DGNLIB) any time soon.
Between what you and Zane have said, I need to create a text favorite for every single label permutation I can imagine. There is no consolidation, because apparently Civil labels cannot be created from a selection of favorites - it is strictly one favorite per label.
Copy an XML into the project/workset and setting the Configuration variable to look to that isn't terribly difficult. I have a workset creation application that already copies the proper template file into the project, so that same code can be edited to copy an XML as well, and a DGNLIB when we do start using them.
Hey Mary, any potential to use a newer version of ORD and just downgrade your DGNs before delivery to the client? Every newer version makes it a little easier to get things done...
Mark
