[ORD 2021 R2] Civil Label Leader not using template level?
I'm not certain what I am doing wrong.
I would assume that by assigning an element template to a Civil Label, that template would control all the relevant features of the label. The leader to my labels is NOT using the assigned element template. It is being drawn using the active attributes.
As an example:
I was placing a few notes for my R/W, so my active level was set to RW_Text. I "realized" that I had forgotten to label a drainage structure, so I opened my Civil Labeler, selected "Inlet Note" and placed the label. The element template for "Inlet Note" is DR_Text. The text portion of my Label is indeed on the correct level, but the leader is not. That is placed on the active level instead.
What is going on here?
It's entirely believable for me to think that people will be doing several tasks at once, or realize they overlooked something and try to get it done in the middle of whatever else they were doing. Yes, it would be nice if everybody stopped to change their active level, but by the time you open the label manager, open the correct XML file (because you can only use one at a time) and find the label they are looking for, they might have overlooked the level. Besides, isn't the element template supposed to control the level (when level is a defined attribute for that template)?
My dimension styles are defined to use the active level because we have several levels we might use for dimensions (depending on target) and even more levels we might use for notes. Is that the problem? If so, that's a really crappy problem because I don't feel like making dozens of copies of the same dimension style just to lock them into a level. That's insane.
Am I just missing a setting?
  • Mary,
    I submitted a Bentley Service Request last fall that sounds similar to this for 2021 R1 (10.10.01.03) and may point you in the right direction. In my case, if any of the Symbology toggles were toggled on in the Dimension Style the leader line placed by Civil Labeler would take on the active level instead of the level being defined by the Element Template. But if all the Dimension Style Symbology settings are toggled off then the Civil Labeler leader line will be place on the level defined by the Element Template.
    A defect was filed, and even though I was also informed it had been addressed, it appears to still be the same behavior in 2021 R2. I have not tried with 2022 R1 but this version replaces the XML with a DGNLIB so not sure if that'll make a difference.
    Matt
    Answer Verified By: MaryB
Reply
  • Mary,
    Matt
  • That sure sounds like it. My dimension styles are coming from the client, and they have dimension and extension lines toggled to linestyle 0 to override any ByLevel linestyle. Great...
    But for that, I only have to create "untoggled" versions of a handful of dimension style. Far better than what I thought I'd have to do!!
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
