while doing rendering in open roads. proper rendering is not showing. i have keep default rendering setting but proper rendering happening.
kindly tell me where is issue.
System configuration is i5 12th generation with 16GB RAM.
Mahavir
There are multiple settings that can affect the render but if you are using default settings then I would guess that you may just need to change the Active light settings to turn off the Flashbulb and turn on the Solar lighting.
Good evening,
As suggested turn off the Flashbulb and turn on the Solar lighting clear image but cyan film is not removed. please suggest how to remove cyan film.
thanks for reply
It looks like you are looking at your model from underneath. I'd suggest to use the rotate view tool to rotate to an isometric view and move the brightness setting in the Vue Rendering dialog to the left until the image appears normal.
The blue tint comes from the environment, VUE is very good at visualizing environments, but you might want a basic - no environment setup as a start.
1 Lightning: I confirm Solar is needed, I would remove Ambient to keep only solar
2 Environment : Create a specific setup, and set all ground values to 0 to remove haze, fog, .... effects.as in picture:
You shall get results similar to the openroads smooth vue.
I have created a "Solar" lightning setup and a "No Atmosphere" environment setup in attached file.To test, reference your model from this blank file and check renders.Basic_Render_Settings.dgn
HTH
Vincent RAULT [Bentley]
As suggested i have turn off Ambient and keep solar lighting on.
In atmosphere ground value zero.
now black tint is visible in atmosphere.
kindly suggest
