Profiles and Sections for existing conditions as inserts in plan view
Example shown from SS2 InRoads.
How can I create a geometry from survey shots along centerline of ditch/spoil break and cut cross sections along that alignment at surveyed locations?  Profile and Cross sections need to be provided as inset in plan view.
  • In SS2, I would create a 3d line along the profile shots and import as a horizontal and vertical alignment.  I could then easily generate a profile.  The surface for the cross sections was created by inserting a breakline feature (so that it could be annotated in the cross section) at each point along the cross section cut line.  Cross sections were then cut and annotated in the plan view.
    I cannot figure out how to accomplish this in OpenRoads.  Can anyone point me toward some instruction for this?
  • There's a lot going on here that has changed substantially from IR SS2 to ORD. Putting your particular project aside, are you familiar with creating profiles and cross sections in ORD, annotating them the way you want, and then printing them independently?
  • In truth, no.  I have worked through numerous tutorials with roadway geometry and corridors where profiles and cross sections are printed to sheets.  But I have yet to reproduce that with my survey data. I am working with the AEC workspace provided by my client.
    I am approaching the profile as a 3d line that I use to create geometry and a profile.  I have not figured out how to print that (with grid control, etc.).
    I am working on creating by terrain with survey cross section data.  To date, it is messy.
    I can cut/print cross sections - but they are empty. The terrain is not showing up.
    Annotating:  I know that I will have to create some annotation groups to annotate the sections.  I have not yet figured out how to "tell" the cross section where my top banks, fences, woods line, etc are - since the terrain does not carry that information (my dtm knew where these triangulalted and non-triangulated breaklines were).
    Whew!  I know this forum is probably not the place to get all these answers.  But perhaps someone can point me to some solid training/tutorials that address something other than roadway corridors.  I am working with survey data and existing conditions only.
  • Gosh, maybe someone here has some magic source of training materials and will speak up, but in my opinion the only way to really learn is to dive in and fight through it until you figure it out. learn.bentley.com has a lot of materials including a learning course named "Under the Hood: Configuring Annotation in OpenRoads Designer", but they're... lacking. docs.bentley.com provides documentation on Microstation and ORD tools, but they're nowhere near as thorough as the old InRoads .chm help files. Bentley also has a lot of YouTube videos, but... ugh.
    Again, in my opinion, starting with your client's or agency's workspace is great, but it's only a starting point. You're often going to want to do something or annotate something that doesn't quite exist in their workspace. In InRoads, this was easy by just modifying some values in whatever tool you were using and then saving your special preferences to an XIN, but now there's a whole nightmare of feature definitions, annotation groups, etc that make any sort of customization really tough for novice users. Also keep in mind that there's the "official" Bentley way to do things and then the practical, real way that you'll do them - which are completely a user/company preference and often totally unrelated to what Bentley explains in their videos (such as annotating things and generating sheets).
    I totally believe it's possible to do what you're after in ORD. I know what I would do, but it would take a day to explain. Stick in there!
  • I think you are exactly right.  I am in a deep dive right now and there's a lot of fight left in me!  Our client wants work delivered in ORD, but still wants .alg/dtm deliverables as well.  So I am straddling the fence with this deliverable.  I think it is important to figure out the ORD way.  I am drowning in You Tube videos!  Thanks for the kind advice.  I will surely follow up on your suggestions.
    My basic plan is to:
    -Create Baseline Geometry for Main Cross Sections. (Can do)
    -Isolate the Main Cross Section Survey points into a field book and bring into dgn. (Can do)
    -Create terrain from Main Cross Section Survey points and clean up with breaklines. (got it mostly)
    -Create Named boundaries at specific locations (working on - they keep coming up at "0" - I do not have a vertical gepmetry)
    -Create Cross Sections and print to sheets (working on - got to get previous working to show existing terrain)
    -Figure out how to get the "features" into the cross sections. (looking for info)
    -Figure out the annotation (there is an annotation group in my workspace for a fence - can use this to figure out how to do the rest)
    To do the ditch profiles and cross sections - use similar plan but with a 3d line imprted to geometry.  Hope to "reference in" cross sections and profiles to dgn (We will see...)
