Hi there,
I am having problems when using the Cut/Fill volume function. I imported a terrain file (DTM file) with the feature definition as Existing, then import an XML file with the feature definition as Design. But when I want to create cut and fill volume the program it is showin "no existing surface found".
Someone knows why it could be this?
-> I´m using OpenRoads Designer CE - 2021 Release 1 Update 10 Version 10.10.01.03
Thanks in advance,
Hi Marina, can you upload the DGN so we can have a look?
Mark
Hi Mark. I would like, but apparently even if I compress the DGN file it is to large to send in here.
Can I send them in another way that is not attached in here?
Hi Marina,
Any file sharing site like dropbox, etc. should allow you to share the files.
Do you want cut & Fill Volume comparion between two surface (To get total Cut & Fill Volume between two surface use Home > Model Analysis & Reporting > Civil Analysis > Analyze Volume) here you will be able to get total Cut & Fill Volume between two surface. Terrain > Analysis>Volume> Analyze Volume
Create Cut Fill Volume: This option only work if you have a corridor and an existing active Terrain. This option is used to get earthwork quantity report station wise from a corridor.
As per the Book, Create Cut Fill Volume should have been created between Two surfaces aswell (having volume options Design Element & Existing Element), But I have also checked this is not working between two surfaces even after assigning the terrain Design Element & Existing element in volume option.
I think we are not able to assign properly the "Design Element and Existing Element" to the Two terrains.
Babulal
