Is MS_DGNLIBLIST the only way to point at the Sheet Seed dgnlib files?
When using the sheet creation tool you select a sheet seed that comes from the sheet seed dgnlib files. Generally for our clients I see these in the Organization-Civil folder and use the MS_DGNLIBLIST variable to point at them. Is it possible to use something like MS_DGNLIBLIST_DRAWINGSEEDS instead and not use MS_DGNLIBLIST at all?
The reason I ask is while most projects will use the sheet seeds from Organization-Civil location sometimes they need to be modified for a project. In this scenario we will copy the sheet seed folder to the _USTN_WORKSETSTANDARDS folder, but we run into issues using MS_DGNLIBLIST to point at them. Since the workset.cfg can't remove paths from MS_DGNLIBLIST, if I just add the project ones via MS_DGNLIBLIST the user will see all the sheet seeds. If I could use MS_DGNLIBLIST_DRAWINGSEEDS then I set it in Organization-Civil, but I can override in workset.cfg by just doing MS_DGNLIBLIST_DRAWINGSEEDS = $(_USTN_WORKSETSTANDARDS)Dgnlib/Sheet Seed/*.dgnlib
Parents Reply Children
