Our organization is just starting to use the ORD Drainage & Utilities package for storm sewer design. We have laid out a storm sewer system and performed an analysis on the system using the software. We also used calculations in our organization's design manual to verify the software's design outputs. From that comparison we came up with the following questions and observations. All the following information is based on drainage analysis using the rational method.
Thanks so much for your help and any information is great!
thank you, Beebe!
Hi Tom,
Beebe posted the three documents. Please let us know in the forum if it answers your questions or if it needs corrections (and what those are).
Thank you Beebe! I got tied up with project work here recently, but will be getting back to this in the near future. I'll definitely go through and make some markups as I go through these and will share those marked up PDFs back to the group!
