I was wondering if there was an easy solution for fixing and end condition that overlaps itself while going around a radius (See Image)?
Any help would be much appreciated. Thanks!
Check this: https://www.youtube.com/watch?v=i4M68gpR4PU
Even though it is in InRoads the proposed solution that is shown, can be easily applied in OpenRoads too.
Hi Jacob,In these situations I find that if I take the linear template around the kerb return, ORD actually trims the overlap/ bow tie.You could give this a try.Snip below for reference.Thanks,Matt
Is there something you have to do for it to trim the overlap/bow tie? I'm still having issues even with using a linear template (see below)
Have you tried the method described on the video?
