I am attempting to support an Engineer that is unable to work with the drainage menu in InRoads V8i.
Some Googling showed we should be able to create an sdb file. When going to File | New there is no drainage option.
Reading the same article it appears as if, "Drainage Structures.dat file needs to contain definitions of pipes and structures". I relayed this information to the Engineer I am working with and he says the dat file does have pipe information. While I am not an Engineer I suspect user error with this situation. How do I verify the dat file has pipe definitions included?
MicroStation V8i (SELECTseries 10)
Version 08.11.09.919
Referenced source: communities.bentley.com/.../drainage-data-file
I received a reply stating, 'InRoads v8i SHA v2 does not have a tool to create a new drainage file (.sdb file)'. Can you please confirm InRoads V8i SHA V2 has the ability to create sdb files?
The product in the InRoads line that can create an SDB file are InRoads Site Suite, InRoads Suite, InRoads Storm & Sanitary and Power InRoads (and possibly Power Civil for North America.)
Thank you for your reply Charles
