In Open road designer- How to populate water/Nala parallel to corridor
 hello
Please look at attached image/screenshot in which i want to populate water between cyan line as Earthen Drain/Nala parallel to corridor. As you can see trees are populate but, I am unable to find "MicroStation Cell library for 'Water" to populate.
Kindly suggest.
