Are Point Controls utilizing Control Type Feature Definition broken in ORD 2021 R1?
I was able to use Feature Definition point controls prior to moving to ORD. Now I use the same work flow and add the corridor references and the template does nothing. Is this a known defect that is perhaps fixed in a later version of ORD? It's also possible I am doing something wrong in the work flow.
Added point control as usual, with selected feature definition.
Corridor reference added with correct feature definition.
