Hello together!
In my projects I have to do with laser scanning in tunnels. From the measured point clouds I have to create horizontal ground views as well as vertical longitudinal sections and cross sections. I can generate the ground views and cross sections very easily by creating sections within the toolbox "Point cloud extended" - "Sections". This also works with longitudinal sections as long as the section line is a straight line, because then it is only a parallel projection of the point cloud in the XZ- or YZ-plane.
But now my question: for the creation of a longitudinal section along a broken intersection line I actually need to wind off the point cloud along this broken path. A simple parallel projection is not sufficient, otherwise the longitudinal section will be shortened. Is there a workflow for this?An additional problem is that the tunnel profiles are very irregular, as they are historical mining. This means that there is no horizontal ceiling and floor or no vertical walls.
I am looking forward to any hints! Thank you very much.
There are no way now to project the actual point cloud, but you can pretty quickly get a line that will represent the point cloud intersection for your alignment.
For profiles, you can use the "Snap to element" tool from point cloud dialog to generate a 3D line that matches the desired (top of bottom) elevation of point cloud.Then projecting this line to profile, you shall get a pretty good approximation of the top and bottom of your point cloud.when using snap to element, play with circle tolerance depending on point cloud density,...
on the print screen, red line in profile is projected profile with top point cloud level,
On the left I overlaid the point cloud (white) with the projection of the line, you can adjust results with Snap parameters.
Workflow:
Vincent RAULT [Bentley]
Answer Verified By: joern may
Hello Vincent,
Thank you very much for your detailed answer.Unfortunately, I have only now found the time to try out your workflow. It quickly gives me good results. In this respect, thanks again!
RegardsJörn
Thanks for feedbackif you found this useful can you please mark this tread as answered :-)
