I'm new to survey side of ORD. I'm trying to find a matching command from geopak in V8i "Compare Points to TIN" for ORD. Is there a similar command in ORD - "Compare Point to Terrain" or something to that effect? Survey uses this tool for ground truthing aerial data against on the ground survey to verify acceptable tolerances.
Any help is much appreciated.
I'm not aware of a point report that includes height differences to a terrain but you could create a terrain from each type of data and then use the Create Delta Terrain tool to compare the two https://www.youtube.com/watch?v=A11Wsu6m_hc
The Analyze Elevation tool within the Terrain tab will report on selected elements against a Terrain.
OpenRoads Designer Accredited
colliersengineering.com
Thanks Shawn, this gets me really close to what I was looking for. Do you know of any reports with that command to calculate the Root Mean Square Error?
