Problem: change stationing, doesn't update the Profile labels in the Profile Drawing Models
Details:
Change the Stationing of a line, the dynamic profile labels update. Cool.
Create a Profile Drawing Model from the Dynamic Profile (via Drawing Production > Named Symbology), station labels are created correctly. Cool.
Change the Stationing of the line, all hell breaks loose. Kidding. Actually NOTHING happens to the Profile Drawing Model Station Labels (they don't update).
True?
10.09.
Fix in later versions?
Is the only workaround to drop and edit the labels (or to re-create the Profile Drawing Models)?
Garcias!
-jeff
Jeff,
Have you tried removing the old annotation and placing new annotation in the profile using Drawing model annotation?
Jan
I don't have any annotation. My issue is the label in the Profile Axis Labels - which is derived from the seed file setup, I think. The labels are "IsAnnotation" which affect size, but I don't see any other connection or updateability.
Hi Jeff, i take it you mean the "new" station range annotation.
Yes, i've seen the same thing. It looks to only update once during sheet creation. I have looked around to see if there is a property or something it is linked to but had no luck.
Mark
Thanks, Mark. Yes, it looks like it reads and sets during creation and that's it. "Drop and Edit" is the workaround. I guess it shows progress that something not live-linked causes alarm. Kind of like when SpaceX expends a booster "Dang, that's a perfectly good booster you're letting just crash into the ocean."
Have you ever seen how well Civil3D handles this type of situation? I am completely frustrated with the sheet production/annotation functions. When will Bentley catch up?
Check my Communities profile if you think I'm an ACAD guy.
