ORD How to update multiple profiles drawing model when created in different files?
In ORD we have the ability to create separate files for plan and profiles.  But how do we update the drawing models of all thoses files? The command "Update All Drawing Models" only works when models are all in the same file (dgn) not when they are separates.  So whats' the tricks?  Batch update with a Key-In Script?
ORD 2022 R1
  • That is correct.  There is no quick update or single button push to accomplish this. I think the solution you presented of using a Batch Process with the appropriate scripted key-ins is likely your best bet.  That being said, I’m not sure you would actually need any specific key-ins.  If the profile Drawing Annotation requires update in any sheet, the act of opening the sheet (with write permissions) would be enough to cause the Annotations to automatically re-fire on their own.  Your Batch Process routine would be fairly simple, but of course, would take some time to process depending on your sheet count.
    -John
    OpenRoads Designer 2022 Release 3 | ProjectWise CONNECT 3.453
