Civil labeller not showing in toolbar .Kindly help
Hello Atif,
Civil Labeler tool is available in latest version of OpenRoads Designer 10.11.00.115. Please refer to the below snapshot.
Purva Lakde
Can you please send me the link of set up of latest version
To get started, copy the imperial or metric out of the box Civil Label dgnlib into your workspace dgnlib folder. Then when you hit the bottom highlighted in yellow above, the tool will open. You may need to adjust the config file if the file name is changes so that the Civil Labeler dgnlib library will open.
