Does anyone know a way to lock points inside a survey field book so there is no danger of unknowingly changing a point location or deleting it?
See if this setting sticks... The tool is found under Drawing Workflow>Home>Selection
OpenRoads Designer Accredited
colliersengineering.com
Yes that works very well, appeciate the help
I selected the cells only and went to properties and then locked the cells, what happens if you delete a cell the point goes away on the field book or if you move the cell the coordinates updates on the field book to correspond to the cells new location.
