Create Terrain Model From Fieldbook Selection Set - Error
We are having an issue creating a terrain model from a field book selection set with ORD 2021R2. At first, I thought the issue related to the link below regarding right-clicking to select multiple field books. However, when attempting to right-click on the "Field Books" header to access the tool - the selected field books deselect and the tool fails. The error is below and reads: Selection set does not contain enough Field Book elements to build a surface.
This issue persists across new files and between users. Has anyone else experienced this issue and/or have any solutions? I know we can find other ways to create these terrain models from multiple field books but I'm certain I've used this functionality before..
Product(s): OpenRoads Designer Version(s): 10.03.00.43+ Area: Survey Question: I want to run the Create Terrain Model from Field Book Selection Set command, by my selection…
Parents Reply Children
