How to Resolve .Net Framework Errors
Hi, I'm trying to open up a Power Inroads file. It was working fine before. I've been getting this same message.
When I try to click continue, Power Inroads shuts down. I've rebooted my computer and even ran the Microsoft.Net Framework repair kit. Still no luck. How can I resolve this?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Bentley.ECObjects.ECObjectsException+ECXMLFormatError: Error while reading ECSchema 'Bentley_Civil__Model_Geometry.04.08' ---> Bentley.ECObjects.ECObjectsException+SchemaNotFound: The schema 'Bentley_Civil__Model_Geometry.04.08' references schema 'Bentley_Civil__Model_DTMFilterGroups.04.08', but that schema cannot be located. ---> Bentley.ECObjects.ECObjectsException+ECXMLFormatError: Error while reading ECSchema 'Bentley_Civil__Model_DTMFilterGroups.04.08' ---> Bentley.ECObjects.ECObjectsException+SchemaNotFound: The schema 'Bentley_Civil__Model_DTMFilterGroups.04.08' references schema 'Bentley_Civil__Model_FilterGroups.04.08', but that schema cannot be located.
   at Bentley.ECObjects.XML.ECSchemaXmlReader.DeserializeSchemaReference(XmlTextReader reader, IECSchema parentSchema)
   at Bentley.ECObjects.XML.ECSchemaXmlReader.DeserializeSecondPass(XmlTextReader reader)
   at Bentley.ECObjects.XML.ECSchemaXmlStringReader.Deserialize(IECSchema schema)
   --- End of inner exception stack trace ---
   at Bentley.ECObjects.XML.ECSchemaXmlStringReader.Deserialize()
   at Bentley.ECXAttributes.ECXAttributes.LoadSchema(IElementRef* schemaElementRef, ECXADgnFileLocateContext locateContext)
   at Bentley.ECXAttributes.ECXADgnFileSchemaLocater.LocateSchema(String schemaName, Int32 versionMajor, Int32 versionMinor, SchemaMatchType matchType, IECSchema parentSchema, Object context)
   at Bentley.ECObjects.ECObjects.LocateSchema(String schemaName, Int32 versionMajor, Int32 versionMinor, SchemaMatchType matchType, IECSchema parentSchema, Object context)
   at Bentley.ECXAttributes.StoredSchemaInfo.LoadSchema()
   at Bentley.ECXAttributes.ECXAttributes.DiscoverStoredSchemas(DgnModelRef* rootModel, Int32 modelIterationMask, Int32 modelIterationDepth, IList`1& outWarnings)
   at Bentley.ECXAttributes.ECXAttributes.EnsureThatSchemaDiscoveryHasBeenCalled(DgnCache* dgnCache)
   at Bentley.ECXAttributes.ECXAttributes.LocateSchema(IntPtr dgnCacheP_as_IntPtr, Boolean useSharedSchemaCache, String schemaName, Int32 majorVersion, Int32 minorVersion, SchemaMatchType matchType)
   at Bentley.DGNECPlugin.ECRelationshipBlockXAttributeHandler.GetOneBlock(ElemHandle* elemHandle, XAttributeHandle* curr, Dictionary`2 dictionaryOfCaches)
   at Bentley.DGNECPlugin.ECRelationshipBlockXAttributeHandler.GetAll(Dictionary`2 dictionaryOfCaches, ElemHandle* elemHandle, XAttributeIter* curr)
   at Bentley.DGNECPlugin.ECRelationshipBlockXAttributeHandler.GetAll(IElementRef* elRef)
   at Bentley.DGNECPlugin.RelationBlockSetCacheRegistry..ctor(IElementRef* elRef)
   at Bentley.DGNECPlugin.RelationshipData.GetRelationBlockSetCacheRegistry(IElementRef* elRef)
   at Bentley.DGNECPlugin.ECXRelationshipsManager.TryGetRelationsEnumerables(IEnumerable`1* relationEnumerator, IElementRef* elRef)
   at Bentley.DGNECPlugin.ECXRelationshipsManager.TryGetAllRelationAccessors(IEnumerable`1* relationEnumerator, IElementRef* elRef)
   at Bentley.Civil.Model.MSPlugIn.?A0xbd7f1969.hasRelationshipsBackPointers(EditElemHandle* eh)
   at Bentley.Civil.Model.MSPlugIn.ElementsToProcess.FillFromCache(ElementsToProcess* , DgnCache* dgnCache)
   at Bentley.Civil.Model.MSPlugIn.ElementsToProcess.Process(ElementsToProcess* )
   at Bentley.Civil.Model.MSPlugIn.ModelManager.ProcessAffected()
   at Bentley.Civil.Model.MSPlugIn.AddIn.ProcessAffected(String unparsed)
   at Bentley.Internal.MicroStation.CoreHook.DispatchNoHandler(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
   at Bentley.Internal.MicroStation.CoreHook.Dispatch(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
************** Loaded Assemblies **************
  • The unfortunate truth is that these .NET Framework errors in the SS10 generation products and older have seldom proven useful to actually troubleshoot file corruption.  This is likely something else entirely that is causing your troubles.  What changed recently with your file?  Was a reference attachment added?  Was an existing reference attachment deleted?  Most likely what you’re seeing is a broken relationship within the file that cannot be resolved due to missing or damaged data.
    If you can sleuth this out and restore the missing data, you might be in luck.  However, it might be that your best course of action is to recover a backup copy of all data and resume from that point.
    HTH
    -John
    OpenRoads Designer 2021 Release 2 | ProjectWise CONNECT 3.453
  • A few things to test:
    • Does the error follow the file to other PC's? If not, it might be a Microsoft update that broke the file.
    • If it does, then it might be a corruption. There is a Civil Browser tool that can be used to try and fix files. It was developed for Bentley internal use, but its existence was discovered by the user community, and some have found it useful. You need to search the posts for more information. It has been some time since I have used it, so I do not recall its key in command,
    However, I have also had files that became corrupted and had to manually rebuild them. These files were corrupted to the point that opening them crashed the system. All I could do was reference them into a new file and use them as a guide while I rebuilt the files.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • If you do not receive a "Newer Civil Data Found" message when attempting to open this file, it is possible that one of attached References is of the CONNECT Platform format (ex. Civil Data has been upgraded to OpenRoads Designer CE 2022 Release 1 schema). You could run the Civil File Manager tool from OpenRoads Designer to check these Files (to identify Civil Schema Version), without opening them to check.
    Matthew Kovach
    Design Systems Administrator
    ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
    ProjectWise Drive 2022.1, Version 2022.1.638.0
    OpenRoads Designer CE 2021 Release 2, Version 10.10.21.04
    OpenRoads Designer CONNECT Edition, Version 10.09.00.91
