Has anyone experienced this while printing, the "Rasterized" check box will not turn off. I'm trying to use print organizer, but some of my prints are printing in color and I can't turn this off. It's random models in one dge file. When I uncheck the box, it keeps turning back on. Is there a setting to override this somewhere? Thanks
Hi Sandy,
Could this be your issue? How to force Rasterized printing to be enabled on Print dialog - MicroStation Wiki - MicroStation - Bentley Communities
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Thank you, Mark!
Yes that helped, and I found a box to check rasterization off, in the print organizer dialog box as well. I just have to be sure to do this every time I print, since it defaults back to being on.
thanks!
Check if a print style is being used, that setting can be turned on there, probably unintentionally. One of the DOTs we work with has the Color set to Monochrome in the print style and we wanted to set up a Color PDF driver and it took me some time to figure out the print style was defaulting the Color to Monochrome.
